Sign Up! To view all forums and unlock additional cool features
Who told you the spark plugs are always to blame? A 2.65 upper with a OD lower is a aggressive boost setup. Engine damage with this is more likely a improper tune. Your tuner needs to have his act together.
i saw this on YouTube, but with 2.85 upper and mostly 10% ATI. All of them had a custom tune for sure, me too. But I think the stock spark plugs are not the best for aggressiv boost like 16-18 psi.
Most of us here do this at that level on e85. I don’t know what to suggest as far as plugs go for the gas you have available. My guess would be a quality NGK one step colder than stock. First question is do you have a tuner that is truly experienced at tuning Hellcats running 16-18 lbs of boost? Is he also experienced at trans tuning for this setup? At over 900hp you need to have the trans properly tuned for the sake of both the engine and the trans. If that’s not available, I would advise against any of it.
Also I Daily drive with 93 pump gas
And My race Tune is for Q16.
I do not need to change spark plugs for when I pully down for my Daily driving 93 Tune.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
