Stock 2020 Redeye Dyno Results
Bordercat_797
Active Duty U.S. Army
El Paso
2020 Dodge CHALLENGER HELLCAT REDEYE WIDEBODY
Hows it going everyone. Ever since I purchased my Redeye back in August I want to put it on a dyno to see what kind of numbers it was putting to the wheel. A group that I am apart of had dyno day at one of our local performance shops and I finally got to put her on. The dyno was a dynojet with ambient temperature around 60 degrees outside. Probably a little warmer inside the garage that the dyno was in. Tell me if these numbers are on par of what a stock Redeye should be putting up.
Thanks for sharing.
What was the DA or is it adjusted at all?
They always try to adjust to try to read similar to sea level I believe.
So I dynoed mine back in November, I was on a little more friendly dyno I think but they also asked me what mods I had because I did dyno quite a bit higher than a customer's redeye they were working on:
https://www.hellcatforum.org/threads/local-dyno-day-coming-up-any-tips.7445/
We like yours better, you win the daily dyno contest Eric!
That is the number I remember. You must have been feeding it steroids.
Bordercat_797
Bordercat_797
El Paso
Wow, those are great numbers. Do you have any stock 60-130 times.
Back in the day it took an act of God to get 700whp and not blow up... now you guys do it without breaking a sweat... amazing.
I don't and at my elevation/DA they wouldn't be mind-blowing, but I will say once rolling and going, my car pulls really good through 4th and 5th gear, super hard!
Indigo Joe
The sticks
The dyno shows SAE correction on the top right which is probably the way the factory would do it. Some of these dynos show the power at the rear wheels to be near to what the factory rates the engine at on a dyno and that makes me chuckle. This one looks more realistic. Like a Mustang dyno. I believe they may be SAE. I'd be happy with those numbers.
