Alpha obd
What about active dampening, if this works about to go buy me a set of lakewoods or vikings
Hatermkr
West bend
2016 helldemon
That’s out and so is tires.
Turn off active dumping
Yes, dumping. Lol
Active dampening is a deep subject...or at least a wet one.
Central Texas
2023 Durango R/T Tow & Go
Anyone here use Alpha obd? I’m trying to find a factory DSRT BCM file and was hoping maybe someone here has one they would share with me?
thanks!
Were you able to source a factory Durango SRT BCM log file?
I'm looking for the same, to compare to my 2023 Tow & go ... which has most of the SRT modules and some features already enabled.
Here's a thread I created asking for the same, but maybe I stuck it in the wrong forum?
https://www.durangosrt.org/threads/looking-for-alfaobd-bcm-log-file-for-2021-durango-srt.13814/
AllthingsMopar
OLIVE BRANCH
2016 Ram
This should get you started.
After having done them myself on my Ram and AlphaOBD myself, adding key fob video does work, but made one statement that isn't true. You can use a used key fob as long as it has been factory reset, meaning back to factory default / unlocked. Only some locksmiths out there have the tool to do that, but if you search online you'll find places to ship your key to and they reset your fob and ship it back to you. So if you find used fobs on Ebay/similar you can get cheaper when they haven't been reset already, but you'll need to consider the time/$$ to go about getting the used FOB's reset. Also note, there are plenty of sellers on Ebay who do reset used OEM key FOB's and they work just fine and they state they are 100% ready to be added or some language of being reset. If you don't want used, I would suggest going on Amazon and getting an after market one New there. Plenty to choose from at reasonable prices.
FYI: You'll know if a used FOB hasn't been reset as it just won't be added to your vehicle, and the logs in AlphaOBD show's the error if it not being able to add it.
AllthingsMopar
OLIVE BRANCH
2016 Ram
@Paladin06, have you tried programming a key with it?
Strange that he shows AlfaOBD giving the PIN, I thought we had to go to the dealer to get that.
Obviously, I haven't tried it yet, just curious.
Version of AlphaOBD out there for sale does pull the PIN for you so you don't get told no at dealer or get charged for it.
