Challenger Hellcat A/C help
Demid22
Nurse
JONESBOROUGH
2017 Dodge Challenger Hellcat
2017 Challenger Hellcat. Has the FI interchiller stage 2 installed. Was working beautifully. No issues at all. I left for work for about 4 weeks and the car got some work done. Now. Shes back together but A/C doesnt work at all. Put a set of Gauges on it and the low pressure side is high(90-110) and high pressure side is low-normal(100-150). AC compressor clutch engages and spins with the compressor. I drained the system. Pulled a vaccumm. Held it for 45mins. Held fine. Went to recharge the system and within 1 can of refrigerant low pressure side is high again. Any thoughts at all?
Surry but sounds like da cuntrol system has bean shorted. It MAY take a cumputer programer 2 reeinstall a new program. Did cha due any electrical wurk 2 da engine at all? Cause it sounds like you burnt da CPU. Dat is wurse case. Utter dan dat, hmm. May have 2 hookem up 2ster da puter 2 tell u why? Seems youz pressures R in line, refrigerant is full, clutch wurks. Leaves da cuntroler. Guud luckster wid dat. Dam programs. Da inter cuulers have dare own programs, if snot mistakun.
Just ware da hellstere is Jonerborough, Tunasee 2 Chattabooga. Neva herd of it. Newz 2 wa. Inturdsting. Ander, just ware doo deez wurds cum frum? Anutter cumputer??
D
Demid22
Nurse
JONESBOROUGH
Im about 3 hours from Chattanooga.
I didnt do any electrical work.
Low side pressure is way too high. And i drained the system and vacuum pumped it down to - 30. Only added 1 can of refridgerant. No way its full.
I can hook it up to computer but im unsure what to look for
D
Demid22
Nurse
JONESBOROUGH
I changed out my intercooler pump to a cwa 400 so. I do have 2 trouble codes for that. Could that be it?
Come on Hick, serious post deserves mildly correctly spelled words.
I know they're hard, but I also know you've got it in you, I've seen it first hand!
zhc
2016 Dodge Charger Hellcat
Your compressor could be flooded if you fed in liquid freon too quickly before the compressor has a chance to process it.
It’s either that or your ac compressor checked out.
D
Demid22
Nurse
JONESBOROUGH
What do you suggest I try to fix the issue?
I thought that was one of his more easily deciphered posts.
If da computah is corectum, it shood pop a code. Bull itster. is dat right hand whore left? Hey, I do feel for the problems here and I am sure these smart individuals can read between the lines. I understand the questions at hand, right or middle finger included, and if I have an intellagant answer it will be held as such. With out being there with Demid, all I can do is inject a small amount of humor into this conversation. Sorry it afends you to read such a language,, sew dew snot read da dam stuff. Youz may smile and brake youa'llz face.
D
Demid22
Nurse
JONESBOROUGH
I deciphered it Hickster and i appreciate your posts. =)
D
Demid22
Nurse
JONESBOROUGH
Additionally im wondering why it stopped to begin with
zhc
If it stops working, it either leaked out enough to become ineffective or your compressor failed. This is assuming that the clutch is engaging properly.
Mr. J,
Thank you for da nice cumplamint. Frum my kno ludge of, ass pecially A/C sysdums anblame such, I dew addempt 2 axport all da know lodge I have, intell lagently ass posumbile. If I affend eany one, well kiss unes ass a tone canasster and muve on 2 da next enpotant question one of da sole ass pointed assperts caan handle. I dew ass pre cee ate da ansewers dat are posted. Sum times our nose getster out of wack and weeze half 2 blame sum 3 turd purty indile und muve unward. Thanks fer da upliften cuments and will keep untertaining. LIKE I SAID 5 ears agoer,, ize bee fer enturd aiment unly. Like da gals at da Diamund Dolls. Buttsturd, sum times dare is a bit of in tall agance cums outward. Surry Bullster. Weez bee on da same page, HCs.
Mr. J,
You do you Hick
He can do better...I have seen it as well...
On dat, I've bee groin 2 da wine stoe. Tanks Bullister an Deemon. Yea know I half spokun engineeren aand stadickets all da life and wood like 2 speek redneck fer awhile. Dun't wurry, itster get back 2 boren aagen.
D
Demid22
Nurse
JONESBOROUGH
I guess at this point, im wondering which components of the AC i need to. Be checking and replacing.
45-70govt
Ghetto
Someday Hickster will surprise us all with something like this. Saw Gone in 60 a while back and for whatever reason thought of Hickster in this scene.
Most likely compressor.
D
Demid22
Nurse
JONESBOROUGH
