18+ Launch Control...do you use it at the track?
Hopefully doing a few more things by the time it gets cooler out. 9.5 or better is the goal
You can try pumping the brakes a few times to build more pressure prior to activation. That will help from over running the brakes.
I've actually had my front skinnies slide on the track causing me to red light as well so you have to sorta feel it out.
Bowlerguy92
I had used it religiously both with the stock motor and my eventual pullied and tuned configuration that I ran a best of 10.1 with. I found it to be very very consistent and easy to use.
However, my first time back at the track with my new built 426 6 weeks or so ago, I set it up as I usually would and staged at the tree pushing about 1600 RPM when the car decided to unleash an unholy burnout instead of holding the stall. Got pulled out of the lane, scolded and banned from that lane the rest of the night. Have over 100 problem free passes there....guess it doesn't matter to them. Clearly a malfunction rather than driver incompetence at that point.
I messed around with different RPM's in the parking lot to see if I could replicate what had happened and it was a very fine balance between stalling the car (big cam) and it just pushing through the brakes and roasting a burnout instead of holding the stall. 1300 RPM seemed to be the right RPM to have neither occur.
Despite that, I settled on probably just foot breaking it from now on. Can't risk a malfunction like that at the tree again and getting kicked out of the track. Guess the stock dodge systems don't like the 426.....
Those tables are torque based if memory serves, so a tune change may help. I'd have to go back and look it's been a while.
Bowlerguy92
Ah, maybe I'll have to bug my great tuner @Jon-MooredPerformanceLLC to update them for me because I certainly do like my launch control :)
Wow they did you wrong
Man now you guys have me wanting to try launch control
Mines a 2015 though. Maybe it’s different, but I know torque reserve was ported to the 2015s
Bowlerguy92
Ya, they quite pissed me off with that honestly. Not really in a hurry to go back, especially after dropping so much on that track over the years not only racing there but also attending all of the NHRA races, etc. The event this happened at was a $200 a pop "extreme prep night" so you can imagine I was extra thrilled to be treated that way after having spent so much.
I ended up going to the tower to talk to the race director both as a "my bad" but equally as a "why are you guys being assholes tonight?" He agreed to let me back into that lane but told me if it happens again, he's got to kick me out. I said thanks, made one more pass where I didn't hook because my Mickey's were shot anyways, then left and haven't been back.
20HCM6 22RENBS2
1.5's in the 60 with LC.
I would have smoked them on the line lock until they were gone for that last time. Heck with that
All this talk has me wondering about it. I’d much rather use launch control, but I wonder how it is for actual racing not test and tune?
Bowlerguy92
I was achieving consistent 1.4x 60 foots in Go Man Go but it took me years to get it dialed in.
Mines a mid 1.4 every time it hooks but by stabbing it. Wondering if launch control will actually work
Stabbing the throttle has a tendency to break stuff. I was stalling mine up to about 1200 and then quickly rolling in to the throttle off the foot brake. LC never worked in my 2016 just blew the tires off every time.
Those are nice times. The best I’ve ever cut was a 1.46, with launch control of course.
The bigger displacement of the engine is going to change the stall. I want to say my car with the 428 it is technically a 1700 stall now on the redeye converter. If it was pushing through like that I would assume he was over the stall rather than making to much torque. At least I think I read that right it started doing a burnout while staging not after the launch.
Bowlerguy92
Gotcha. Ya, this happened at the tree while sitting in launch control mode as you understood correctly. Held the stall for a second and then just did a fat burnout.
Is this something we can adjust in the tune or do I just need to stall it lower? Like I said, it's really hard to find a balance between the motor stalling in launch control or lighting the tires up it seems.
I never try to launch over 1500. If you wanted to go higher so the tires do not start spinning you’d need a higher stall torque converter.
Bowlerguy92
Alright, I'll play with it some more when I can get back to the track. It seemed like it was pretty happy at 1300 RPM which should be more than enough. Will just make sure I keep it on the lower side now.
