2020 Redeye shifting hiccups
Idoru99
Springfield
VA
2021 Challenger Redeye WB
TSB = Technical Service Bulletin
Has anyone tried to shut off the traction control completely and see if it still hiccups? If I get mine out this weekend, it is going to be real cool so it will tend to want to hiccup to save its mechanical self. I will try to play around with the traction and stability totally off. I have noticed the better it runs and IF it catches a bit of wheel spin at the top RPM’s it pauses that shift IMO to save itself or the driver. It is a bullshit hiccup and Dodge needs to optimize whatever they are trying to do in the program.
@DodgeCares you in on this? How can you help the majority of us?
JDOTZ
Cherry Hill
2020 widebody redeye
Thread Starter #23
I did 3 runs in track with traction and stability completely off and the last run was track with sport traction
Shit. It still hiccuped?
JDOTZ
Cherry Hill
Thread Starter #25
I just posted a few of my thoughts in the other thread. Thanks @EricG for reminding me to review what we all posted a year ago, and we still have nothing from @DodgeCares or Dodge anybody, and it reminded me they generally ignore us GOOD customers. There is lots of good stuff to buy right now.
Hpmaniac
Port orchard
2019 redeye
My TRX does this sometimes on the 2-3 shift but only in sport mode.
Phast Hemi
SHELBY TOWNSHIP
This issue is normally associated with improper tire pressure and or poor track conditions. Ive always been able to remedy this with proper tire settings. Nothing wrong with the cars, you just need to learn what the car wants. The so called hiccup results from the engine coming up on the limiter too fast due to excessive wheel speed in most cases. Other remedies can include running a 2.62 gear or taller back tire.
JDOTZ
Cherry Hill
Thread Starter #29
So I started that night at 17psi in the rear and the track was holding it well. Each run I added half a pound and was going to continue to go up until the track wouldn't hold it anymore. I can tell you I'm 100% sure I wasn't spinning at all. I also have a taller tire. I'm running a 315 50 17. I do have the upgraded option from the factory for the 3.09 rear. I have a few buddy's with redeyes and none of their cars are doing what mine is doing. Their cars are all 2019 with varying options some have a 2.62 amd some a 3.09. Some run 305 45 17 and some run what I have. My other buddy is coming with me on Friday to run his for the 1st time and his is identical to mine as far as year and rear. We will see what happens this Friday but I'm pretty confident it's not what tire pressure, tires, or rear I'm running. Appreciate the info and I will try to go lower in pressure and will keep ya updated.
DodgeCares
Auburn Hills
2020 Challenger SXT
Hi @JDOTZ , @Idoru99 , @Slowpoke387 , @Hpmaniac and @DGatzby ,
There is a STAR case that appears to address concerns similar to the symptoms that you are having with your vehicle. To ensure this STAR case applies, we would like to get you into the dealer to have a qualified technician review the details of the STAR case and specifics of your vehicle. Once reviewed, the technician can then perform the repair procedure that best matches the symptoms and diagnosis of your vehicle. The STAR number is STAR S1821000001.
Rob
Dodge Cares
DodgeCares
Auburn Hills
2020 Challenger SXT
Hi @DGatzby ,
Thank you for the tag and bringing this to our attention.
Rob
Dodge Cares
white1
Prairieville
LA
2020 hellcat charger widebody
Have you tried other modes besides track? I know its a different transmission, but I've had customers with scat packs have a similar issue in track mode, but not in sport or normal mode
JDOTZ
Cherry Hill
Thread Starter #33
I have not. I will try sport mode and a custom mode. The reason why I run in track mode is because it turns the fan on. I have a 2020 widebody and can turn the chiller on in any mode but in the 19's it only turns on in track mode.
Indigo Joe
The sticks
How much fuel did you have in the tank ?
JDOTZ
Cherry Hill
Thread Starter #35
Hi @DGatzby ,
Rob
Dodge Cares
Thank you Sir. I will work with my great dealer on this. Good info.
DodgeCares
Auburn Hills
2020 Challenger SXT
Sounds great! Please feel free to keep us updated regarding your situation.
Rob
Dodge Cares
^^^Technical Service Bulletin.
NJ_Redeye
Audubon
2019 Challenger SRT Hellcat Redeye
@DodgeCares
Rob, Can you get us any info on what this update provides, and when it was released?
TRANS:
21-046-18 - Flash: Transmission Control Module (TCM) Updates
TIA
Rob
Dodge Cares
es
DodgeCares
Auburn Hills
2020 Challenger SXT
@DodgeCares
TRANS:
TIA
es
We are happy to help! I have attached TSB 21-046-18 below.
Rob
Dodge Cares
