AlfaOBD Mods
Thread Starter #41
You know what else is cool to activate? Memory with FOBIK.
It commands the number one setting, from the memory settings (seat, outside mirrors, radio and in think climate control).
If I've been detailing the car and everything is out of whack, I can unlock, with the FOBIK a d all the settings revert to Memory 1.
Yours may already be set. Mine, on my 15 HC wasn't.
Bob
Thread Starter #42
I'm considering installing adjustable pedals. A member on LXForums (Gapi) did this and turned on everything with Alfa.
It's the only thing I miss about how my 6.1 was equipped.
Bob
Thread Starter #43
Bob, is there a publicly available Google Drive folder containing the BCM reads from other models/trims?
Contact Paladin06.
Bob
Bob
Charger only, correct?
Thread Starter #45
Charger, Challenger, RAM trucks, Jeep (various models).
Bob
Bob
Challenger doesn't have a memory to return to?
Certainly doesn't have a button anyway.
Thread Starter #47
Well, it's on the list of compatible vehicles.
Perhaps it's how the vehicle is optioned? My last Charger didn't have memory, but a friends did.
Either way, you can only mod whatcha have ;)
Bob
Thread Starter #48
How to:
DISABLE TPMS WARNINGS AND MONITORING.
VehConfig 3 Base TPM system present: NO
VehConfig 3 premium tpm system present: NO
VehConfig 5 non regulated tire pressure information system: NO
VehConfig 7 TPMS configuration: Logic 1 NHTSA Enable Warning
Reset the rf hub.
No beeps, buzzes, lights, or error messages on screen.
Tested and verified.
Bob
How to:
Reset the rf hub.
Bob
Been looking for this THANK YOU.
@Diboblo anything else to contribute? I can’t figure out how to get the paddle shifters to show up in transmission/drive option on the uconnect. I disabled eco mode a while ago 🤣 wonder if that has something to do with it
Looking for a 2015 challenger hellcat A8 read please, all options except for sunroof. Preferably the windows friendly version
Sub'd
Eustis
2015 Challenger SRT/70RR
#53
I know this is an older thread...hopefully someone will still respond. I am looking to modify my 2015 BCM to remove numerous body modules for systems I will not be using in my 70 RR / 2015 Challenger project I am building. Im using the entire drive train, dash , interior and wiring form a 2015 SRT into a 70 Road Runner. SOME of the systems I need to DISABLE would be:
AIR BAGS
Anti-Lock brakes
Power WIndows
Power Locks
Rain/Light Sensor
Active Suspension
and Im sure there's more.
Some of the above mentioned might reside in the PCM.
ANY help would be appreciated. AND do you know of some company that would be able to do this IF I cannot?
Can’t turn off abs, car won’t start or work. Everything requires abs activation
Eustis
#55
Thats not what Ive been told by others....
AllthingsMopar
OLIVE BRANCH
2016 Ram
#56
I've used AlphaOBD and OBDLink MX+ Bluetooth adapter on my Ram for adding FOB's since when I bought only came with 1. For Ram Truck you had to get the PIN for the vehicle to make some changes. True on Challenger/Chargers? If so there is a good link HERE that shows how to get with latest version of AlphaODB App.
If you try to add a FOB from Ebay, ensure the listing says one of these: Guaranteed and ready to program or remote is unlocked. Basically this means that the key FOB has been reset to factory settings and is ready to pair to your vehicle, even though it's been used before. New of coarse is good to go. And you can buy a key FOB and have (some, not all do this) locksmith reset a used FOB to factory settings. But without a used FOB being reset, you can NOT add it to your vehicle until it is. But it is possible.
Monroe
2025 TNG
#57
Hey guys.. newbie here. Picked up my 2025 TNG 20th anniversary. Comes WITHOUT auto dimming headlights. Long story here.. but.. rearview mirror is identical to ones that have the Auto Dim working. Headlights are autoleveling. Forward collision is also on this vehicle.
So in AlphaOBD android version, I made all needed changes to enable the Auto dims to work. The option in Uconnect is now available. When I push the turn signal stalk to High Beam position with the light dial set to Auto, I do indeed get the message "Auto HighBeam Enabled".
The problem is that the Highbeams NEVER come on at night even on the darkest of roads.
So this has led me to believe that I need to do a Proxi Alignment. Problem is that I cannot find that option in AlphaOBD android version. Come someone on here assist/guide me. Thanks so much.
dodges don’t do proxi alignment on the bcm
#59
Does the auto sense for headlight work? The one that auto turns on headlights when light is less than daylight..twilight evening or dark underpass,. see how dark it has to be for that to work. Not sure, but if I remember correctly there is a setting to adjust sensitivity, it is equivalent of front "camera", on the rearview. you can also try just covering the sensor and see if the headlamps auto switch to hi-beam. That should tell you if everything is working or not.
Madrid
Spain
Dodge Challenger Sxt 2016
#60
Hi guys, greetings from Spain. I have a 2016 Challenger Sxt. The ambar DRL are no "legal" here so the car comes with the white ones as standard. Anyway, I buy the Veepeak OBD and Alphaobd, see a few videos and try to change it to the ambar DRL, in the value "Drl lamp location" i set it in turn signals, but now i have the ambar halos + side turn signals + back turn signals ON all the time, i only wanted halos. In the screen i selected DRL OFF and now its all off but i really want the ambar halos. Anyone knows what can be happening? 20241208_153402.jpg 20241208_153407.jpg 20241208_153414.jpg
